佛山市南海万格士机械设备有限公司
Foshan Nanhai Wangeshi Mechanical Equipment Co.,Ltd.
主营:喷砂机,隔热设备,热剪炉,多棒炉,真空木纹设备,挤出机,穿条机,注胶机
铝道网  >  铝设备 >  挤压生产线  > 模具加热炉  > 模具加热炉,节能环保模具加热炉
模具加热炉,节能环保模具加热炉
电议 元/台
  • 所在地:广东 佛山
  • 供货总量: 100000
  • 发布时间:2013-04-01
佛山市南海万格士机械设备有限公司,专业生产模具加热炉铝棒加热炉,电磁感应模具加热炉。功能:加热铝材挤压模具
工艺方式:模具-加热-挤压机
特点:1.PLC自动控制,温度控制精准,温差可控制在15摄氏度以内,模具加热到设定温度后,自动保温;
PLC cool,temperature coolling precisely ,temperature difference is within 15℃;when die temperature reach setting temperature,keep heat automatically.
2.人机界面和面板按钮控制操作,参数设置简单直观,维护方便;
Operate by touch-screen and button,set parameter easily,convenient to maintain.
3.高效:加温时间15-25分钟;加热模式可设置,操作简单;
High efficiency:heating just need 15-25minutes,heating mode can be set,easy to operate.
4.节能:与普通模具加热相比:节能60%
Energy-saving:compare with traditional die heater, electromagnetic die heater can save 60% energy.
5.采用先进智能的隔离磁能感应加热,使得生产过程中安全系数大大提高,设备使用寿命更长;
Adopts advanced isolate electromagnetic induction heating,increase the safety during production,cause long useful life.
6.快速换模,减少作业时间,提高生产效率,达到节能省耗得目的。
Change die in high efficiency,reduce wong time,increase production efficiency,save energy.
7.保温层采用耐1300摄氏度高温棉制作,减少不必要的能耗;
Adopts high temperature resistance cotton for keeping heat,the cotton can resist 1300℃,which making energy saving.
8.度检测采用两点温度检测,使采样到的温度更精准;
Adopts two point temperature test ,test temperature precisely.
9.加温温度曲线:温度曲线实时监控温度值,温度变化值,直观显示温度达到设定值所需要的时间。
Temperature diagram monitor temperature ,temperature change value on time,show the heating time intuitively.
温度历史记录:
实时记录簿同时间的温度值,可记录长达30天,甚至更多时间的温度值,有效的监控工人工作中的违规操作,避免加温温度不够就取出模具使模具损坏。
Record the temperature value at difference time,can re core over 30 days even more longer time’s temperature value ,which can monitor the abnormal wong during production effectively,and avoiding die damage because of die temperature is not enough.
低温、高温自动报警功能:
当温度未达到设定温度,按模出按钮时,自动报警,阻止取模,免避模具损坏;当温度超过设定温度时,自动报警。
When temp.did not reach setting temp.,click’’die out’’button,alarm automatically,then stop taking did out,avoiding die damage;when temp.over setting temp,auto alarm.
其他供应
总经理
